Changing CMS Cluster Directory Path
Hi,
I want to set up a separate shared drive for my Daz Content. I'm guessing that I should probably change the CMS Cluster Path to the shared drive as well.
But, since it's in the AppData folder, I'm wondering if doing so will majorly mess everything up.
Does anyone know what is the correct way to proceed?
  • Richard HaseltineRichard Haseltine Posts: 111,430
    In DS use Edit>Prefernces>CMS Settings to change the path, then move the folder, with DS, DIM, and Carrara closed. You can have multiple databases for different content sets in Content Directory Manager.
  • Deadly BudaDeadly Buda Posts: 155
    Oh thanks. That's cool I didn't know that was the case.
