Problem with "Old City Center" and renderer thats starts over
clearly the developer of this city has done some trix to the preset rendering settings as i cant find whats causing the problem.
link to the city:
https://www.daz3d.com/old-city-center
renderers starts over after 5K iray iterations and it doesnt matter how high i set min samples and max sample.
they are the same as i usualy have but some hidden settings? causes the render to start over.
and also when the render starts over it only uses the CPU for rendering and you know how effective that one is ;)
any clue why this is happening?
GPU: RTX 2080
GPU mem usage when rendering this city with one G8 female caracter 7600MB.
also it doesnt matter how low i set texture compression
4096/2048 or 1024 doesnt change the problem
and the rendering settings
open it with notepad.
i can see right away that it says MOVIE FILE
but when i check renderig type i have it as STILL IMAGE
so the question is: how can you get access all settings in Daz 3D?
clearly there is more than the settings you have under Editor that you need to change here.
