Error message after using IM & DS 4.6
mrfuscomrfusco Posts: 0
Hi all-
After being away from DS for a bit because of work, I came back and upgraded DS to the newest version and installed the Install Manager. While it's easy to use, I can't seem to figure out why I'm getting this error message when trying to load the new GIS Biosuit:
/data/ToxicAngel/GIS BioSuit/Genesis Helm/bodysuite_helmet_scaled_8291.dsf
I've tried changing install paths, uninstalling and reinstalling DS and the content and even installing manually... nothing. And this is only ONE problem I'm having now...
Any help would be appreciated.
  • fixmypcmikefixmypcmike Posts: 19,738
    Odds are that DS4.6 has retained your old settings and therefore the default path in DIM is not listed in DS.
    Can you post these 2 screenshots:
    1) In DS, Edit > Preferences > Content Library > Content Directory Manager, expand the "DAZ Studio Formats" and "Poser Formats"
    2) In DIM, on Ready to Install tab check the "Show Details" box in the lower right
  • mrfuscomrfusco Posts: 0
    Here you go... I was wondering if it was because of old paths
    1120 x 973 - 192K
    1920 x 1080 - 453K
    Yes, you need to either add the path DIM is using as both DS-format and Poser-format in DS, or add the DS path to DIM and install there.
    That worked. Thanks for your help!
