Ironman13 - i13 Library Environment missing destroyed version
bought i13 Library Environment and missing the destroyed version of it. anyone else has the same problem?
  • barbultbarbult Posts: 27,489
    I've owned it for some time already. I installed it with Daz Connect, and I have the destroyed version. In the Content Library, the destroyed version is in a separate folder called LB Destroyed Version. The Scene file is called I13LB DST !Ready to Render. The preload is called I13LB DST !Preload.
  • Lothar WeberLothar Weber Posts: 1,611
    Thank you. I ve also installed it with connect... missing it in the smart tab. Found it in the Content tab... strange surprise
    how can i get it in the Content tab under the i13 library product? Any tips?
    It shows for me in Smart Content Products.
    582 x 432 - 63K
    Maybe reinstall will work. Will try that later... daz is Rendering rightn now... wink thank you for your answer
    Still after reinstall it is stuck in the content pane. Can’t get it in the smart content. Any tips for me?
    Show a screenshot of the same section I posted, so I can see what you see.
    Managed to get the screens... ;-)
    368 x 569 - 118K
    529 x 533 - 133K
    Those screenshots show that your metadata is incomplete. In the content library screenshot, most of the items don't have any content type label across the top. One scene does have the Scene label,  but the other scene does not, and the props do not have the Prop label. Other metadata like category must also be missing, which prevents it from showing up in the Smart Content pane. If other products are working correctly, it might just be a problem with this product installation. Have you tried just uninstalling I13 Library Environment , updating metadata, and reinstalling it?
    Hmmm....I'm starting to get suspicious that maybe I added the missing metadata for this product myself. I've owned it for so long, I can't remember. If reinstalling doesn't fix it for you, you'd better submit a help request to Daz and ask them to fix the product metadata. Or, you can add metadata yourself with the Content DB Editor (if you are comfortable editing metadta!!).
    Thank you for your help. Already reinstalled. No change. Yes. I’m able to use meta editor to a specific level. But how can I get them to the suited „library“ products. That’s my problem.
