Content Library - How to move items?
When I categorized products early on, I threw all of the clothing in the Wardrobe folder thinking that I could go back and move dresses, pants, bathing suits, etc into their own sub category later.
This does seem to work for all of the products that have a grey icon with a U on it.
However, when I right click on one of the products with a white icon there is not the option to move it.
What do the different colors of icons mean?  How can I change the white ones to grey so that I can move them?
Thanks!
  • NorthOf45NorthOf45 Posts: 5,896
    The grey folders with the U are for User-defined categories, and can be manipulated at will. The white folders are the built-in default (and a few vendor) categories and cannot be changed, nor should you need to. The metadata for all products refers to these default categories, so changing them would really foul things up.
  • AncientWireAncientWire Posts: 143
    Thre are a great many white icons within custom categories that I created, so they could have not been put there by default.
    To categorize my items, I went into Products, chose one, right clicked and chose Create Category From, then chose the destination category in Category / Default.
    Interestingly, I can rename an item in Products, but I can't rename an item that I am about to, or have already categorized.
    If its under a white folder icon, it is read-only. You have to copy it somewhere else to make changes. Not entirely sure how it gets that white icon making it read-only, but I have seen it happen when changing metadata from the products view, or restoring User Data.
    Maybe it is from restoring my data. I have changed computers since I started organizing my items.
    Thank you
    If that's the case, just copy the whole branch somewhere else, and delete the original, taking care not to remove a real default category. I have a completely separate branch under Categories, parallel to Default, for all my custom categories.
