MacOS 10.14.5 CMS connection could not be established
Hi. I can't for the love of god make daz studio connect to the postgres db.
What i tried:
resetting the host file
reinstalling postgres via IM
Granting all permissions within little snitch
deactivated proxy settings for local (127.0.0.1)
is there anything else i could try?
  • TotteTotte Posts: 15,045
    What does the CMS config say?
    I'm looking into this, but if you look into the DS log (clean it before running ) do you see log items about postgres in it?
    OK, one thing to check. Do you have a DAZ Connect directory setup and is the DAZ Connect directory in the Content Directory Manager pointing to it correctly? Found a fun issue with that when I tested for your issue.
  • PlatnumkPlatnumk Posts: 682
    Open DAZ Preferences,  Goto the CMS Settings tab & make sure that the Cluster Directory is pointing to the corrent folder,  The default folder should be /Users/YOUR USR NAME/Library/Application Support/DAZ 3D/cms
