Dforce and Alts
Memory Object Allocation Failure is my error. Curious as to what this is meant for am I using the graphics card because if I am for this sim that would be a crap thing. Because my graphics card is a Name NVIDIA GeForce GTX 680 (2gbs) my computer is a bit old as in 10 maybe more now (also Windows 10). I mean I am taking donations if you want to toss me something more. My ram is relatively good at 32gbs but it is also that ancient (Sandy Bridge i7 I think...). If it is due to the graphics card is there a way to I dunno switch it to ram? I do have Marvelous over here but every time I try to do anything in it acts pretty stupid, to be frank. With the scene set at cm, it is too sensitive to a few things like scrolling in and for some unknown reason when I hit sim the cloth vanishes. In this case, though Dforce is apter since I can weight paint the buttons which I do not think I can with Marvelous.
Again though if you going to suggest to get a new graphics card like substance painter tells me to do when I open it that isn't happening any time soon (maybe in another decade). Reverting the drivers would be a nightmare due to other softwares requiring it to be at the latest and greatest.
Oh yeah, of course, forgot this is just for obj cloth. Dforce cloth works somewhat but I do have issues of well with one that had a hood the hood just went forward and then twisted wrapping itself around the models face as if it was some living entity that decided it was ruler over life and death.
  • Richard HaseltineRichard Haseltine Posts: 108,735
    There is an Intel OpenCL driver for CPUs, you might try that. It's linked from https://www.daz3d.com/forums/discussion/203081/dforce-start-here#latest
  • Not quite sure what I am supposed to do there. The thing they put says no updates available.
  • I am also now having the issue where some dforce stuff just out and out crash Daz as soon as I hit simulate, other times it gives me an error message. Sometimes both.
  • Yeah, I am getting this error a lot with dforce clothing currently.
    ERROR: clEnqueueNDRangeKernel (-4)
  • Excede a certain muscle index it seems to break dformer/cloth even if it is set for it.
    2019-07-25 13:48:43.321 WARNING: ..\..\..\src\dzdynamicsengine.cpp(2951): ERROR: clEnqueueNDRangeKernel (-4)
    2019-07-25 13:48:43.768 Total Simulation Time: 5.90 seconds
    I am betting it is some morph somewhere. Been testing extremes guess it is time to just test morphs one at a time. I will holler if I figure out which one it is.
    1196 x 1574 - 112K
  • I have no clue I deleted the model took it even further than the above, and all works well. I dunno why. This is an intriguing bug but also a bit annoying.
  • Hmm... it is a memory thing I think. On the test subject I removed the hair and it ran it. Now I will test it on my actual subject and see. Still dunno how to make it use the CPU.
  • Dclothes to a degree work with enough memory minus a few insta crashing ones. However .obj to dforce does not work. I do not have money for a new computer and won't for a while. If I do upgrade would Daz work better with the latest and greatest everything or would some weird thing fail?
  • If you haven't already, get gpu-z and see how much ram it's reporting beign used, or go to Program files>Nvidia corporation>NVSMI copy the nvidia-smi.exe file over to c:\users\admistrator, then run a command prompt and type Nvidia-smi, it'll report certain information regarding the card including ram usage.
    Although i've gotten mixed results with consumer cards on SMI, it just shows maxed used ram on some cards for some reason.
    Switching to cpu mode in dforce: Simulation settings tab>Advanced sub tab>click the dropdown and select your particular cpu. There may be a couple options depending on the particular cpu you use, so you may need to try either to get the best results.
