Changing my Avatar is not working.
Knight22179Knight22179 Posts: 1,195
Time and again, I have tried to change my Avatar. I remove it, then upload a different one and no matter what, it always ends up being the same one! I log in, log back in, nothing changes.
So, how can I change my Avatar?
  • frank0314frank0314 Posts: 15,094
    What file format are you trying to use?
  • Richard HaseltineRichard Haseltine Posts: 111,306
    Have you done a forced refresh - ctrl-F5 in many Windows browsers? Often the forum doesn't seem to tag updated files with the same name as needing redownloading. Changing format - from jpg to png or vice versa - is another way to force a refresh.
  • Knight22179Knight22179 Posts: 1,195
    @Frank0314: I'm trying to use .jpg
    Tried the Ctrl-F5 but it didn't work. Changing my Avatar to PNG did the trick. Thanks, Richard.
  • Subtropic PixelSubtropic Pixel Posts: 2,403
    I had this problem once. The solution was to go to bed, and when I woke up 8 hours later, it was fixed!
  • RogerbeeRogerbee Posts: 4,460
    edited December 2013
    That's right actually, though for me it took about 3 days!
    I changed it to the one there is now, but had the same problem. Then I assumed it hadn't worked and forgot about it. I was making posts a few days later and it suddenly changed. I guess the system gets a bit laggy from time to time.
    CHEERS!
    Post edited by Rogerbee on
