Help installing renderosity files in Daz
acedrakeacedrake Posts: 41
I am not sure how to do so, but please help me with this. Please help
  • ruekakaruekaka Posts: 348
    Depends on what you bought.
    Usually you get one or more ZIP files.
    Unzip them and just copy/move the content of the ZIP files into the same folder structure you use for your "MyLibrary"
    (You can find this folder by looking at "Edit -> Preferences", Select the tab "Content Library" and click on the "Content Directory Manager".
    (e.g. if the ZIP file contains a folder with the name "Runtime" copy the content in your "Runtime" folder).
  • TjebTjeb Posts: 507
    edited December 2013
    If you are not sure of what you are doing and don't want to mess up your file structure,
    you can always 'drag and drop' items from the .zip to the folder of your choice.
    In my case I use winrar.
    Open the .zip file but don't extract it, just double-click on an item and most likely again double click,
    then drag and drop the item on, for example, the character folder.
    493 x 395 - 49K
    Post edited by Tjeb on
  • srieschsriesch Posts: 4,243
    Note that a lot of the free content I find on Renderosity varies in how it is packaged. You might need to move files around if they aren't in the expected locations. Make sure in DAZ Studio you have mapped the folder in which the runtime folder exists so it knows where to look for your content, and run the search for new content. If you are having problems with a specific set of folders, a screenshot showing the top of your folder structure and your mapping in DS might help us identify the exact cause of the problem.
