Dforce Doesn't Work Right
I got a new computer just when 4.11 came out. It is fantastic, renders literally takes seconds in some cases now. However, Dforce hair and clothes is giving me fits. When I clock SIMPULATE simple setups take a long time. Complicated ones will never finich. I tried letting one run overnight and it went from 51% to 58% after running 10 hours. Is this a 4.11 problem? New computer? There is a setting I am not aware of? Worked OK on the old computer with 4.10 though it was slow but slow was better than never finishing.
  • Richard HaseltineRichard Haseltine Posts: 111,795
    What is the OpenGL Provider (Advanced tab of Simulation Settings)?
  • mwokeemwokee Posts: 1,275
    That appears to be it, the option was not set for my video card. I will have to play with it to verify. I seem to keep finding the things not covered in the online tutorials.
    edited July 2019
    Still having problems. The simulation runs and completes now but I still have instances where the clothes explode into a graphical mess. The text below is from the error log after the simulation ran:
    2019-07-21 15:44:14.035 Spring(47584, 47605) of node "Granny Nightgown" extended: rest length < collsion offset (0.161013 < 0.20001)
    2019-07-21 15:44:14.035 Shortest spring had length: 0.0228234
    2019-07-21 15:52:15.807 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): recv failed errno=10054
    2019-07-21 16:04:29.274 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): recv failed errno=10054
    2019-07-21 16:17:07.943 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=0
    2019-07-21 16:30:07.344 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=0
    2019-07-21 16:32:07.703 WARNING: ..\..\..\src\dzopenclkernelfactory.cpp(32): Open CL notify: CL_MEM_OBJECT_ALLOCATION_FAILURE error executing CL_COMMAND_NDRANGE_KERNEL on GeForce GTX 1080 (Device 0).
    2019-07-21 16:32:07.719 WARNING: ..\..\..\src\dzdynamicsengine.cpp(2956): ERROR: Memory Object Allocation Failure (-4)
    2019-07-21 16:32:07.828 Total Simulation Time: 48 minutes 23.52 seconds
    2019-07-21 16:43:36.724 WARNING: ..\..\..\..\..\src\sdksource\cloud\dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=0
    Post edited by mwokee on
    There are various things that can cause an explosion - the cloth getting trapped between two intersecting body parts, for example, or unduly rapid changes in pose without increasing the number of sub frames in Simulation Settings.
