Error When Using SickleYield UltraTemplates for G3F
When i try to use any template from this set except for Short Wide Dress, I get an error saying that the projection template can't be found. As best I can tell, the relevant files are exactly where they always were under /data. I haven't tested the male counterpart as exhaustively, but the preliminary tests seemed okay. Has anyone encountered this?
  • Richard HaseltineRichard Haseltine Posts: 110,480
    How did you install?
  • OdaaOdaa Posts: 1,548
    DIM. I uninstalled and reinstalled both this morning and got the same errors. The RSSY conversion scripts that I own (the two G8 to G3 products and the two G2 to G3 products) got quirky around the time I upgraded to DS 4.11 (possibly slightly before), bringing up prompts demanding that I pick a projection template, and I kind of wonder if the two are related.
