Running Out of Space
So at nearly 5k files on my laptop, Daz has officially sucked up enough of a terabyte that its starting to cause issues with other programs due to lack of space. Short of deleting everything than just manually downloading individual files, is there way to archive things here on the site so that I can just delete everything and then let the downloader replace only what I want?
  • Richard HaseltineRichard Haseltine Posts: 111,348
    You could use a larger drive, as an external (assuming that suites your usage pattern). You could also use an external to archive the zips and install from those as needed. For content from Daz, using Connect will offer to download and install missing items (but that obviously needs a connection).
