Ideal Rig for realtime iRay
inacentaur
Just curious if there is such a thing as an ideal rig for realtime iRay - i.e. be able to move camera, etc, with iRay view being in realtime or close to
No.
iRay preview/viewport is using the actual render engine and every time you change poses etc. The render has to be started again.
The best way to use iRay viewport is through the aux viewport. Use texture shading in the main viewport and then when you absolutely have to see the scenein iray open the aux viewport.
