why does it render in a wider box?
ToobisToobis Posts: 993
So when I do an Iray render I want it in this instance to just be the thin viewport as shown (pic1) yet the render comes out with the defaul render size (pic2) what am I doing wrong please?
1920 x 1080 - 311K
1920 x 1080 - 299K
  • KnittingmommyKnittingmommy Posts: 8,191
    edited July 2019
    Your render size is set under the Render Tab. Look at the section called General.
    Choose the Custom tab to access all the presets that come with DS:
    Or you can select a specific size if you know how many pixels you want the hight and width. You can also set the aspect ratio if you have a specific aspect ratio you know you need, and then change size keeping that aspect ratio.
    Edit: You might also want to make sure your Aspect Frame (Click on the Perspective/Camera View) is on so you can see exactly what is inside the render camera:
    580 x 641 - 72K
    585 x 540 - 62K
    354 x 316 - 23K
    Post edited by Knittingmommy on
  • ToobisToobis Posts: 993
  • DripDrip Posts: 1,270
    If you frequently render in some custom size, you can also save that setting, so it will appear in the drop down box for more ease of use later. For example, I often use Daz Studio to render backgrounds for my mobile phone, which is 1440x2960 pixels. So I saved that setting, and can now simply select "Mobile BG" from the Dimension Presets box.
    Also note the "Render Target" parameter in the first screenshot. If this is set to "Viewport" (I think this is the starting default) then the render will be whatever the Viewport size is — and this is not fixed, it's just whatever space is left over between the left and right pane groups, and different panes have different minimum widths. Setting it to "New Window" (as seen above) or "Save To File" lets you define whatever render size you want.
  • AlmightyQUESTAlmightyQUEST Posts: 2,006
    edited July 2019
    A note that probably doesn't apply here, but if in the future you find that you are getting render sizes that don't match what you put in your render settings, check the camera in the "Dimensions" section to see if "Use Local Dimensions" is enabled. This isn't a common issue, but can happen if you load a previously saved camera.
    Post edited by AlmightyQUEST on
