Body 'indentation' from AlphaKini for Genesis 2 and 3 Female(s)
Reality HackReality Hack Posts: 111
Hi. I'm having an issue with the Alphakini by Aeon Soul. When applied to the figure, it leaves an 'indentation' at the edges around the neck, chest, and waist. However, when it's removed from the scene, the indentations remain, and it just looks something like terrible fat folds, and I can't for the life of me find where I can remove the morphs left behind.
Also, it would be fine and 'realistic' if the actual cloth texture were taking up all of the surface areas, but when applying the SciPatches texture from the Future texture add-on, the rest of the material is invisible, so the folds are still there with no apparent material that's supposed to be causing them.
I could simply start over with a fresh figure, however, I've already applied a lot of morphs to this figure that I can't possibly remember, and I'd hate to have to attempt to recreate her from scratch.
Here's an image of what I'm talking about:
Image removed
Please help! I really don't want to have to try and recreate her. Thanks.
  • Richard HaseltineRichard Haseltine Posts: 111,315
    If you select the figure and in the Parametrs pane look in the Currently Used gorup do the moprhs not show? How about if you enable Show Hidden Parameters from the pane's option menu (the lined button in the top corner, or right-click the tab)?
  • Reality HackReality Hack Posts: 111
    omigosh. Thank you so much for the prompt reply. You know, I must have hundreds of parameters that are currently being used, but wouldn't you know it, I just so happened to notice one that looked like it toward the very top of the list...and it was. And from that one I was able to guess the other one. Thank you so very much!
    And for those curious, the names of the settings are AS-AK Bra HD and AS-AK Pantie HD. (Set them both to 0.00 to remove the morphs.)
    Thanks again!
