SOLVED: Move Custom Morph to Shaping Tab?
asdf123asdf123 Posts: 167
edited July 2019 in The Commons
SOLVED: Found my answer here. Durrrrr. Sorry for the post spree
https://www.daz3d.com/forums/discussion/42942/how-do-i-move-morphs-from-parameters-tab-to-shaping-tab
Hi,
I have successfully created a morph and added a thumbnail, but it's currently only visible within the Parameters tab.
How can I move it to the Shaping tab?
It's a G3F to G8F conversion
Thanks for any help!
Post edited by asdf123 on
  • Matt_CastleMatt_Castle Posts: 3,307
    edited July 2019
    Have you set the path in the Morph Properties and it's still only showing up under Parameters, or have you still got it set to the default Morph/Morph Loader?
    In any case, this implies you're not using the GenNext script for your G3F to G8F transfer, because GenNext would put it under the correct category automatically. As GenNext is a free open source script, I would suggest retransferring the morph that way, as GenNext is much less prone to errors in transferring teeth and eye shape than any manual method.
    Post edited by Matt_Castle on
