import victoria 4.2
media_1b4d42c6df
had daz studio 4.5 for over a year and have not used it for the same reason I´m having problems with 4.6, can´t import anything into it like victoria 4.2. used to hit search and daz woulod bring all the content int but this... so how?
thanks in advance.
Victoria 4 is in Poser format, so you will find it in the Content Library pane under Poser Formats > My DAZ 3D Library > Figures > DAZ People.
Where is your content installed to? Have you listed your content folder in Edit > Preferences > Content Library > Content Directory Manager as BOTH DAZ Studio Formats and Poser Formats?
You may also be having problems with CMS (Content Management Service) which DS uses for the Search function in the Content Library pane. CMA also runs the Smart Content and Products and Categories (among other things)
I have no content installed because I can´t find away to bring it into DS. and yes I have been to preference but see nothing to help bring in content. and yes I may be having problems with CMS, considering I don´t see it or anything to do with interface. I finally just imported victoria the way I would an obj.
later KD
See the image below, you MUST have at least one folder that holds content listed as BOT DAZ Studio Formats and Poser Formats before you will see the content inside DAZ Studio.
I would suggest using the DIM (DAZ Install Manager) to install your content, and that way, it will all go into the correct folders. I have a lot more folders listed than most people have, but you don't need that many, but you MUST have at least one.
Where did you install the content to, and HOW did you install it. If you download the content yourself from the DAZ 3D site, it comes in ZIP files. You must empty the contents of the ZIP files into a folder you intend to use as a library folder, then add that in Preferences as already shown.
