Lantios lights give these errors, any suggestions to fix?
KharmaKharma Posts: 3,214
I get these errors trying to use lantios lights in DS 4.6. The lights load but when I render I get the following results posting in picture along the top lip. any suggestions as to why I get these errors and the resulting render flaw?
1600 x 900 - 731K
1600 x 900 - 560K
    These are .loaded from a DAZ Scene file, you will need to look in the log file to see what is missing. Help > Troubleshooting > View Log File.
    The usual problem with DAZ Scene files is the data folder. Make sure that the lights are installed to the correct folder, and that the folder which 'holds' the data folder, is listed as a DAZ Studio Formats folder in Edit > Preferences > Content Library > Content Directory Manager.
  • KharmaKharma Posts: 3,214
    I installed them with DIM so I assumethey should be installed correctly unless it didn't download all the files, but I will check the log file if you can tell me where to look for it ?
    In the Help menu as posted previously :)
  • fixmypcmikefixmypcmike Posts: 19,742
    Can you post these two screenshots:
    1) In DS, Edit > Preferences > Content Library > Content Directory Manager, expand the "DAZ Studio Formats" and "Poser Formats"
    2) In DIM, on Ready to Install tab check the "Show Details" box in the lower right
