Just Bits Iray Shaders don't display outer heights
Hi,
I tried to get on a primitive sphere peaks  like in the main product pic (yellow/black shader) of Just Bits Iray Shaders.
https://www.daz3d.com/just-bits-iray-shaders
I took iray uber shader on a sphere and the preset. There were no heights like in pic.
Then adjusted several parameters but it doesn't work. It is only a sphere with a "flat" surface.
Do you have any ideas?
  • MelanieLMelanieL Posts: 7,867
    I suspect your sphere doesn't have enough faces in the mesh for the shader preset to work on. Try creating a sphere with more facets, then maybe subdivide it too (from the Edit - Object menu somewhere) and try the shader preset again.
  • chromchrom Posts: 261
    Thank you.
    I already did. But tried again and now it worked.
    (At first time I unfortunately also counterproductively increased the primitive from 1m to 10 m.)
