Daz Installer question
When using DIM, and I filter on Poser application.  I get 647 items and it is dowloading them an installing them, but the Poser installation is not growing in size.  Where is the DIM installing the items?
If it is installing them in the DAZ database that seems odd, as it might as well install them for Daz Studio.
Can I use the Daz Installation Manager to install the 647 items in my Poser Directory structure to keep from having to manually install the files?
  • LeanaLeana Posts: 13,630
    It installs them to the path you selected as “current path” in DIM before installing.
    You can definitely install to your poser library. You need to add that path as an install location in DIM settings first (use the cog in the top right corner, go to Install tab and add the path to the list), and then when you want to install something there you select that path as current install path in the list at the bottom of DIM window, and then install the content.
