Any Settings To Reduce Curvature on Flat Surfaces When Smooth Is On? Please See Jpeg.
mechengineer97mechengineer97 Posts: 116
edited July 2019 in The Commons
[Any Settings To Reduce Curvature on Flat Surfaces When Smooth Is On?  Please See Jpeg.] Very noticeable when there's a seam like between 2 car doors making flat surfaces curved.  Turning smooth off turns blends into sharp edges.  Hoping there's some settings that will help.
Just in case the attached image doesn't work, here's a link  https://www.freeimage.us/share-6D92_5D2694C0.html
906 x 522 - 41K
  • JamesJABJamesJAB Posts: 1,766
    edited July 2019
    In the surfaces tab, each material has an option for smoothing angle.
    If you look at the attached image you can see how it affects how an object is drawn.
    824 x 1862 - 376K
    Post edited by JamesJAB on
    Holy crap, thanks a bunch for taking the time to create the screenshots.  I was playing with that angle prior to posting, but used only 75 and 120 degree as the min and max and there was no noticeable improvement.  But knowing that this angle was what I needed to use, I went down to 35 degrees and it solved the issue.  Thanks again !!!!!
    Link just in case the attachment doesn't come through.  https://www.freeimage.us/share-4398_5D26A7D6.html
    1172 x 783 - 74K
    Looking good, though it does look like it could use some more polygons around the door handle indentation on the doors.
  • Oso3DOso3D Posts: 15,116
    Smoothing normals is one thing I absolutely love about Iray.
