Maisie for Teen Jane 8 body morph rigging issues?
Is anyone else having issues with Maisie? Using pretty much any posing control produces warped results with the body morph applied, even as small as using the eyes up/down control. It isn't occuring on any other figures, including Sara for Teen Jane 8 or Jane herself, and uninstalling and re-installing hasn't helped. Applying the Maisie body morph to G8F does the same thing as well, so it looks like it's just limited to this one morph.
  • IllriggerIllrigger Posts: 12
    Here's Maisie with Eyes Up-Down set to -100
    1470 x 1363 - 1M
  • 3Diva3Diva Posts: 12,058
    I don't have her so I can't test it. If you're only experiencing it with this one character I'd put in a support ticket: https://helpdaz.zendesk.com/hc/en-us
    Yes, big problems because there are TWO Maisies for G8 and I think they are interfering with each other...
    929 x 677 - 478K
    When I tried to remove the current Maisie with a slider, I saw that there was another Maisie and there was a question mark and 2 next to her. The only way to remove this Maisie is through shaping with no dial. Her expressions are all off, something weird is happening probably related to the other Maisie.
    I've only got the newer one, so that's not the issue on my end. Good catch, though - usually they are better at this stuff.
    Can a mod report this? Or is it up to us. The new Maisie doesn't work at all and also conflicts with old Maisie...
  • ChangelingChickChangelingChick Posts: 3,448
    Y'all should go ahead and file tickets for it because they may need more info that the mods won't have.
  • GordigGordig Posts: 10,810
    edited July 2019
    This may explain why I haven’t been seeing renders of the new Maisie. That’s a bummer, since she was probably my favorite part of the Teen Jane launch.
    Post edited by Gordig on
  • If something is broken the person who finds it needs to open a support ticket, the forum moderators will not do that.
    She can load from the file but has no slider, and expressions don’t work on her at all, her whole face bugs out. I’m so sick of writing tickets. I hope someone else does it. It’s so time consuming. There should just be a thread: products that don’t work and tech support should check it every day. Why are we always the beta testers?
  • Richard HaseltineRichard Haseltine Posts: 111,688
    Have you tried unchecking Consolidate Properties in the Parameters pane option menu - that might split the sliders so you can use them, and relabel one pending a fix (assuming the issue is reported)
  • RobotHeadArtRobotHeadArt Posts: 917
    Did this issue ever get resolved?
  • nicsttnicstt Posts: 11,715
    edited July 2019
    I reported this issue a week or so ago, explaining there are two characters with the same name.
    Haven't yet been advised it has.
    705 x 310 - 29K
    Post edited by nicstt on
    Easy enough to work around; just uninstall the FWSA character whilst creating the render with the new Masie
