Fade out using opacity & Animate?
I was trying to make an object fade to invisible over 1 second using animate by adjusting the opacity. Animate is not recording the adjustments. Is this not possible with Daz?
  • Richard HaseltineRichard Haseltine Posts: 111,908
    Not with the default shaders, but you can do it with Shader Mixer using a Variable brick to get the frame number, feeding that into a binary operation brick to divide by 30, then another to subtract from 1 and finally into the opacity.
  • SorelSorel Posts: 1,438
    You can use this script here
    https://sites.google.com/site/mcasualsdazscripts/matanim
