Paint/Texture program what do you use?
DestDest Posts: 2
Whqat do you artists use to pint textures on? Specifically over seams.
  • Virtual_WorldVirtual_World Posts: 1,105
    Mudbox
    edited July 2019
    Depends if the seams are between tiles in a UDIM layout, or just multiple islands or left/right on the same map (ie a Daz figure's center seam down the back).
    Substance Painter can handle the latter, but you'll need something like Mudbox or Mari for the former. I think 3DCoat may be able to handle UDIM as well.
    Post edited by Lissa_xyz on
  • Blender texture painting.  Doesn't support UDIM as such but will paint across seams nonetheless.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,801
    edited July 2019
    Zbrush
    needs UDIM or not overlapping UV’s
    can paint on the overlapping UVs but need to mask and hide surfaces to export maps find that a pain myself
    sometimes use Carrara
    which does overlapping UVs as separate maps at once as well as UDIM but is not as accurate as Zbrush but you do get pretty instant feedback on your actual multiple maps
     Sculptris can too with limitations
    you need your mesh triangulated and AFAIK not UDIM and not overlapping UV’s
  • DustRiderDustRider Posts: 2,921
    I use Blacksmith 3D (at Renderosity). It's relatively simple to use. Blender is probably the best free option, with the 2.8 Beta being the easiest version to learn/use IMHO.
    Mudbox
    Just to point out that you can get Mudbox from Autodesk for $10 / month. Might be worth a 1 month trial to see if it works for you?
  • Oso3DOso3D Posts: 15,127
    I use Mudbox. I keep hoping to roll that functionality into another app but none of the others quite do it.
  • ragamuffin57ragamuffin57 Posts: 132
    really just starting  to get to grips with Substance painter
    JonnyRay said:
    Mudbox
    thank you JonnyRay  for the heads up on the low subscription on mudbox  might try as well !!
  • MatCreatorMatCreator Posts: 216
    whats udim?
    aside from that, 3d coat is really awesome for painting too
  • Richard HaseltineRichard Haseltine Posts: 111,972
    whats udim?
    Using a unit offset along the U axis to separate materials - the way the daz humans have used a separate group of textures, each taking the whole of the unit square, but by giving them an offset an aplication that is UDIM-aware can automatically separate the groups for painting (instead of having a strok affect all the maps which use the same fractional values).
