Pose Preset
luciocolisanluciocolisan Posts: 10
edited July 2019 in Daz Studio Discussion
Hello,
I am trying to understand how the pose presets works. I edited a Daz file in DSON editor, and I noticed that after I apply a pose to a character DAZ modifies the values of Rotation, Translation, Scale for each node (hip1, head, neck...so on) belonging to Genesis2. I edited these parameters manually using notepad++, I saved the file, and opened with DAZ and the pose was correct. (I used a naked Genesis2 male).
After I dressed the character, I saved the file and changed the same parameters with Notepad++, but the resulted pose was quite different from the pose preset.
Is there other values than Scene/Nodes - Translation, Rotation, and Scale that a pose preset change for a dressed character? I cleaned the pose preset parameter using preset cleaner, I let only the bones parameters, but the result was the same.
Could you please help me understand which parameters DAZ change to a file when I apply a pose preset?
Many thanks!!!
  • Richard HaseltineRichard Haseltine Posts: 111,306
    edited July 2019
    Moved to Daz Studio Discussion as it isn't a scripting question.
    So you edited a scene file (with the clothes) or a preset? Either way, I would suspect a simple slip of the finger editing the wrong property or assigning the wrong value.
    edited July 2019
    I dont understand your purpose for hand editing pose information manually in the DUF file.
    What are you trying to accomplish manually that you cannot do inside DS directly?
    What file type are you saving as?
    Post edited by Mattymanx on
