anyone else have these problems??
TrishTrish Posts: 2,625
I have this bear but when I try to load the version with the fur it does this........................
1111 x 509 - 246K
    This bear does need a very robust system, it is very heavy on resources.
  • TrishTrish Posts: 2,625
    edited December 2013
    I think I am afraid to buy the fur for the lions because of this bear...Do you know if they would be the same ??? heres what I have with a NVIDIA Ge Force -GT 630 graphics card also and 2TB HD
    536 x 74 - 25K
    Post edited by Trish on
    There were a lot of people who were having problems with this model when it was first released.
    It does predate the release of LAMH, which as far as I know is not nearly so resource intensive.
    I know I looked at both this and the Wolf, but decided that I didn't think I would bother due to the warning on the wolf product page about needing a fast robust system.
    I will see If I can find Alessandro or Kendall to come talk to you
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,809
    LAMH different to the bear which is a conformed geometry mesh
    That bear is very taxing
    I would really like to have the kitty kitty fur but only if my system can pull it off....I also get bogged down with the lost world and the forest it doesn't lock up but man it is slow trying to move around
  • Kendall SearsKendall Sears Posts: 2,995
    Hi Bullit,
    LAMH is less resource intensive than the conforming fur that is on the Bear. The specs that you listed should handle LAMH with no sweat. It should also handle the Ursos pretty well. The BC2 presets load and render great on an AMD Quad-Core A6 with 4G of RAM which is one of our test machines.
    I also have an i7 here, and you should check what speed your processor is actually running at. The i7 will throttle back as more cores are used, and even further back if the temp in the machine rises. It is not uncommon to find that an i7 has throttled as far back as 0.9Ghz (yes 900Mhz) when all cores are in use. There have been reports of even further throttling when thermal limits are hit.
    If you are seeing a slowdown on loading large models, then you might want to investigate.
    Kendall
    Kendall: Thank you very much...appreciate your help
