Genesis to Genesis 2 autofit Problem
Beat578Beat578 Posts: 191
Hi. Since the last Update i have a problem: When i try to autofit a genesis Cloth to Genesis 2 then I dont see Genesis on the autofit window. I can only select form "Victoria 4 Skirts", "Victoria 4", "Genesis 2 Male" or "unsupported". All other Entries seem to be missing.
I had them before, that im sure of.
I uninstalled all DAZ Studio 4.x and DAZ Studio 4.x Beta content and all Genesis and Genesis 2 Base products and reinstalled them.
With Genesis, all is ok, i have all the selections there, but Genesis 2 seems to bee missing some. Can i somehow install them manually? Or what part do i have to reinstall again?
Thanks for your help!
Regards
Beat
  • nightwolf1982nightwolf1982 Posts: 1,324
    My Library\data\DAZ 3D\Genesis 2\Female\Morphs\DAZ 3D\Base
    Check this directory for a file named CloneGenesis.dsf. This is the Genesis Autofit Clone. If it's not present, you may need to re-download the Genesis 2 Female Starter Essentials.
    Are you having the same problem with the Genesis 2 Male?
  • Beat578Beat578 Posts: 191
    Thanks for the Tip Nightwolf
    Its strange, the Path was like you said, i found the Base Morph. But I remember having the Base Folder direclty in
    So I copied the Base Folder to that directory, and now It works, i Have my genesis clone back. Its strange.
    I dont know if its a bug in the Auto fit, or in the installation.
    Well, it works now, hope it stays that way. Thanks again.
    You're welcome. As long as the clones are located in a directory under the Morphs/DAZ 3D path, they should work.
