Slow performance with two 2080rtx
Hello guys...recentlyi installed 2 2080 rtx (one of them is ti) and while i was expecting really amazing performance the opposite happened... in another computer with 1 1080ti when im loading a character while im moving around camera i can see live the textures on it on iray... in my pc ( which is a powerfull one 64 g of ram etch) when im moving around the character is goes white ( preview without textures) and after a sec it loads textures etc... do you know why this is happening! I have latest nvidia studio drivers in my computer...
  • fastbike1fastbike1 Posts: 4,081
    edited July 2019
    Everyone says they have the latest Nvidia drivers, but that is never clear. Better to specifically state the driver version. Also the Studio version you are using. The Studio versions 4.11 require a minimum Nvidia driver of 418.81. There have been some reports of the Nvidia 430 series drivers not allowing GPU rendering. Also, did you get the drivers direct from Nvidia? If they came from Windows, they're not the right drivers.
    You could also check the Studio Log (Help>Troubleshooting>View Log File) to see what messaagess it has for the renders.
    Post edited by fastbike1 on
  • ISIKOLISIKOL Posts: 386
    Hello fastbike..im using the latest nvidia studio drivers from nvidia site...i havent loged in the log file yet....but i will do that... but im sure that something else is wrong..can you please point me to the info that you have that the 430 are creating issues with daz studio!?
    does anyone makes sense from the below?
    2019-07-07 15:46:37.928 Iray INFO - module:category(IRAY:RENDER):   1.21  IRAY   rend info : CUDA device 0 (GeForce RTX 2080 Ti): Scene processed in 0.281s
    2019-07-07 15:46:37.931 Iray INFO - module:category(IRAY:RENDER):   1.19  IRAY   rend info : CUDA device 0 (GeForce RTX 2080 Ti): Allocated 41.371 MiB for frame buffer
    2019-07-07 15:46:37.932 Iray INFO - module:category(IRAY:RENDER):   1.21  IRAY   rend info : CUDA device 0 (GeForce RTX 2080 Ti): Allocated 1.6875 GiB of work space (2048k active samples in 0.000s)
    2019-07-07 15:46:37.938 Iray INFO - module:category(IRAY:RENDER):   1.18  IRAY   rend info : JIT-linking mega kernel in 0.022s
    2019-07-07 15:46:37.938 Iray INFO - module:category(IRAY:RENDER):   1.20  IRAY   rend info : CUDA device 1 (GeForce RTX 2080): Scene processed in 0.291s
    2019-07-07 15:46:37.941 Iray INFO - module:category(IRAY:RENDER):   1.18  IRAY   rend info : CUDA device 1 (GeForce RTX 2080): Allocated 30.7849 MiB for frame buffer
    2019-07-07 15:46:37.941 Iray INFO - module:category(IRAY:RENDER):   1.20  IRAY   rend info : CUDA device 1 (GeForce RTX 2080): Allocated 1.6875 GiB of work space (2048k active samples in 0.000s)
    2019-07-07 15:46:37.941 Iray INFO - module:category(IRAY:RENDER):   1.20  IRAY   rend info : CUDA device 1 (GeForce RTX 2080): Used for display, optimizing for interactive usage (performance could be sacrificed)
  • Richard HaseltineRichard Haseltine Posts: 109,570
    Nothing strikes me as out of place, though I'm not clear why they would have different frame buffer sizes..
    Not specifically, there have been a host of threads w/ RTX render issues. The first several drivers for the RTX wouldn't allow GPU renders for Iray. IIRC, similar issues have been suggested for the 430 drivers. Nevertheless, it takes very little time to change drivers. If you are using Windows 10, you may have had a "stealth" GPU driver update and realize it.
    The initial issue was that Iray did not support the 20x0 cards. The version in the 4.11.x.x betas, and now in the 4.11.0.363 release version, does support the cards but has a minimum driver requirement. The RTX features themselves are not yet supported (at least n a publicly available version of DS - I gather then new version listed in the change log will use RTX features).
