Textures - make up
Hi All
I have the Jolina model and added make-up from another model but as one can see the textures are slightly out. What is the best / easiest way to align the two? Specifically the make up rather than the rest of teh bodies skin texture.
663 x 690 - 1017K
  • GordigGordig Posts: 10,805
    Unless the makeup is LIE (layered image editor) based, the “makeup” is actually an entire face texture that has makeup on it. Thus, if you want the makeup from a particular model, you should probably use the whole texture set.
  • plarffplarff Posts: 287
    MMmm that is the problem i like the skin texture im using now..
  • Richard HaseltineRichard Haseltine Posts: 111,430
    You could try opening the base and make-up maps for the character you are getting the make-up from in an image editor, add them to a new image as separate layers, and set the blend mode to Difference (which should be black where there is no make-up and grey where there is). Add a levels or the like adjustment layer and make the grey areas as near white as you can, leaving the black black. Save the result as a make-up mask image. In DS instead of applying the make-up preset go into the Surfaces pane and, if this is using the Iray Uber Base shader, load the mask as Diffuse Overlay Strength and load the make-up texture as the diffuse Overlay colour.
  • fastbike1fastbike1 Posts: 4,083
    Then find a different LIE makeup.
