blush face effect for victoria 4?
ToobisToobis Posts: 993
Is there a blush face effect for victoria 4 at all? I have seen ones mentioned for G3 and other later figured but not Victoria 4 ever. Can anyone suggest one I can get here or anywhere if there is one? thx.
  • There's always the PhotoShop/GIMP method. If I need extra blush or something similar, then this is the easiest for me.
    What rendering engine are you using? If Iray, then simple maps in the Diffuse Overlay channel can do a lot (unless it's already being used for makeup).
    You can also just airbrush some red/pink onto another layer over the Face diffuse map, and adjust opacity for that layer to fit the look you're after before you export. It might take an experiment or two to get exactly the look you want.
  • ToobisToobis Posts: 993
    Nice ok i'll try those. Thx :)
  • TaozTaoz Posts: 10,345
    This set has one:
    Instant Makeup RM Everyday Beauty  -  https://www.daz3d.com/catalog/product/view/id/10877
  • Do you mean blue as in makeup, or blush as in embarrassed?
  • SlimerJSpudSlimerJSpud Posts: 1,456
    You could also use the Layered Image Editor. All you would need is a simple roundish blush image, then apply it to each cheek on separate layers and adjust the transparancy to control just how embarrased she is! That way, you could try it with different base textures too.
    blush
