Download Manager consistently fails to download
TheMysteryIsThePoint
I wanted to install all my purchased content onto a new laptop. I installed 4.11 and DIM, but when I select everything and it starts to download, nothing succeeds, literally every item says "failed to download". It's been this way for several days. My desktop and another laptop on the same account, continue to work fine; it is just this new, third laptop that doesn't work.
I've been careful to not use them at the same time, and it only complained about exceeding my concurrent limit (which I assume is 1) one time while trying to connect to DIM while I was in Daz. But that was after the problem manifested itself.
Anyone know what gives?
Thanks,
Donald
Post edited by TheMysteryIsThePoint on
I assume they all use the same internet connection? Have you checked the permissions on the Downloads folder, or tried chnaging it to a different location (gear icon to open Settings, Downloads tab)?
@donalddade
Check your anti virus software. Some of those applications act more like a virus (controlling machine, using cumpute cycles) than an actual virus.
Thanks to you both for helping out. To Richard, yes, same connection, permissions seem ok (not sure how permissions work in Windows, but I can create an empty file in that directory). To fastbike1, it doesn't seem to be that... there's nothing in the logs but I could be ignorant of how it works.
But I found some suspicious things in the log. From the laptop that doesn't work:
+++++++++++++++ Install Manager 1.2.0.27 starting +++++++++++++++++
OS bits: 64
Platform bits: 64
Qt Version: 4.8.7
Locale: en_US
Running on Windows 10, Build 9200, No Service Pack Installed
Physical Memory:
Total: 31.9 GB (34262564864)
Avail: 29.6 GB (31805984768)
Virtual Memory:
Total: 127.9 TB (140737488224256)
Avail: 127.9 TB (140737229127680)
Current Memory Usage: 7%
Current DateTime:
Loc: Sat Jul 6 20:42:22 2019
UTC: Sun Jul 7 03:42:22 2019
Application Data:
Location = C:/Users/donal/AppData/Roaming/DAZ 3D/InstallManager
Disk Total: 931.4 GB (1000186310656)
Disk Avail: 889.2 GB (954777165824)
Reading dzInstall.ini
Current Account: Donald A. Dade
Current Download Path:
Location = C:/Users/Public/Documents/DAZ 3D/InstallManager/Downloads
Current Content Install Path:
Location = C:/Users/Public/Documents/My DAZ 3D Library
Current 64-bit Software Install Path:
Location = C:/Program Files
Current 32-bit Software Install Path:
Location = C:/Program Files (x86)
Starting CMS...
Connected to CMS: PostgreSQL 9.3.4, compiled by Visual C++ build 1600, 64-bit
Product 60413-1 has the same name as 60413-2:Cinematography & Editing in the Unreal Engine
Product 53261-1 has the same name as 53261-2:Manga Marker Materials for Genesis 8 Female
Product 52195-2:Classic Long Hair with dForce for Genesis 8 Female(s) Tutorials has no tags
Product 42071-3:Genesis 8 Starter Essentials Mimic has no tags
Product 16281-2:Victoria 6 PoserCF has no tags
Processed 369 products with 506 unique product downloads
WARNING: SSL Error: 11 - The issuer certificate of a locally looked up certificate could not be found
WARNING: SSL Error: 17 - The root CA certificate is not trusted for this purpose
WARNING: Network Error while downloading to file "": SSL handshake failed
<this error is repeated many times>
Now, I understand that SSL certificates can be used just for confidentiality via encryption without a root CA if you don't care about authentication or the connection is being authenticated via some other means, and for that reason, the error might not be fatal. But my desktop that works does not get this error. And it seems unlikely that on a fresh install of Windows 10, what, Microsoft just decided to install a bad root CA?
And from the desktop that does work:
OS bits: 64
Platform bits: 64
Qt Version: 4.8.7
Locale: en_US
Physical Memory:
Total: 63.8 GB (68590501888)
Avail: 51.1 GB (54974504960)
Virtual Memory:
Avail: 127.9 TB (140732928221184)
Current Memory Usage: 19%
Current DateTime:
Loc: Sat Jul 6 20:52:01 2019
UTC: Sun Jul 7 03:52:01 2019
Application Data:
Disk Total: 931.0 GB (999691829248)
Disk Avail: 408.0 GB (438125748224)
Current Account: Account
Disk Avail: 408.0 GB (438125744128)
Starting CMS...
Processed 444 installed products, totaling 102.3 GB
Are you using the same security software on both machines?
Yes, at least in the sense that I didn't change any of the settings after installation. But you and fastbike1 are both pointing in that direction, so who knows, maybe I did something different during installation. I'll investigate further; thanks to both of you.
