saving my pp2 props to native DS format?
MistaraMistara Posts: 38,675
the goal was to load a finished .pp2 prop from poser folder, apply a DS shader from the mixer and save the prop to DS mylibrary.
i see stuff on the ds46 menu for create a product, scene subset,
then it says dson duf.
i don't want to save it as a poser dson prop, wanted it in native DS format.
do i need to copy the image maps from the poser texture folder to a mylibrary texture folder?
am i better off to import the raw obj files to DS instead?
thanks!
  • Richard HaseltineRichard Haseltine Posts: 111,990
    edited December 2013
    DSON is the native DS format - it's a DSON Importer for Poser, to enable the import of DSON fiels from DS. If you want a fully native file, use File>Save as>Support Asset>Figure/Prop Asset.... The names you enter in the option dialogue determine the folder names in the Data folder for the asset files, the file save prompt is for the user/library file, not for anything that goes in the Data folder.
    Thank you! i didn't notice the support asset option.
  • fictionalbookshelffictionalbookshelf Posts: 837
    if you are point the surface settings to retrieve the textures as the same folder as the poser version you wouldn't need to change locations of textures.
    I package my Daz & Poser props like this
    data -my name-product name
    Props - product name - daz mats (they retrieve the files from runtime texture folder)
    runtime -prop - my items
    runtime-materials-my item's mats for poser retrieved from same folder as daz version)
    well that's not a real good explanation but I hope you get the idea.
