Lost access to all DAZ Connect content
desertpicsdesertpics Posts: 10
I bought several items this morning and some of them did not intall correctly. I always install from within DAZ rather than use DIM but tried messing aroound with DIM to see if I could reinstall the products that had not installed correctly. I changed the path to the content database base (not a good idea...) and now nothing shows up in the smart content pane. I do have the path set to install to my D drive rather than the defaults as my C drive is a small SSD. I am certain nothing got deleted, I think I just need to figure out the correct path.
It is curerntly set in DIM to D:/Files/DAZ 3D/Studio/My Daz Connect Library/data/cloud
I think there was one folder after cloud but it was a numbered folder and there are a bunch of them in the cloud folder, can anyone help?
Post edited by desertpics on
  • Richard HaseltineRichard Haseltine Posts: 111,332
    DIM should not isntall to the Data/cloud folder - it should always point to the folder that holds the Data and Runtime folders, assuming that folder is selected as a Daz Studio and/or Poser format content directory in DS. That isn't the CMS database path in any event, or did you chaneg that too? If so have you tried changing it back?
  • desertpicsdesertpics Posts: 10
    Thanks Richard. Originally the only thing I changed was the path shown in DIM and all my smart content and DAZ connect folders in the contant library were gone. If I go to products in teh content library everything is there but shows as not installed and will install if I click on it. I guess I could just reinstall everything but it would be quite an undertaking.
