Suddenly No Right-Click Select in Studio View Port
Fragg1960Fragg1960 Posts: 363
I don't know if this has happened to anyone, but have you ever suddenly lost the ability to right click-select in the Studio view port?
I worked in Studio yesterday for a few hours and all was well (right-click select was working). Fired it up this morning and put in a couple more hours (saving as I went along--no issues). I then tried to select a body part in the view port and nothing happened when I right click on it (you usually get the sub menu pop up).
I restarted Studio and no go. I rebooted the system--and still no go. I loaded a couple of files I worked on yesterday (to see if the error was file/scene-specific) and nothing--won't work.
System Specs
DS 4.6.1.33
Windows 7 (64-bit)
8.0 GB RAM
Intel Core i7-4770K CPU
NVidia GeForce GTX 650 Ti
This is pretty annoying. If anyone who's had a similar experience and fixed it could help out it would b appreciated.
    Are you using the Translate tool (Alt+Shift+T), and did you have the tool Settings menu open at any point yesterday, you may have changed something by accident?
    If you select a body part in the Scene pane, does it show you the Translate Gizmo in the viewport? Have you tried loading a fresh figure from the Content Library pane to see if that works.
    I have not heard of this happening before, maybe someone else has?
  • Fragg1960Fragg1960 Posts: 363
    Got the functionality back. Don't ask me what I did. I rebooted again and waited a while, then opened the scene and it was back to normal. Didn't change any settings in any of the tabs. I wish I knew what caused it in case it happens again. Oh, well--thanks for the input.
