Witchykin Outfit for G8F: Hat adjustments not working!?!
Just bought me that Witchykin Outfit today and noticed, when trying to adjust the fit of the hat, that none of the adjustment sliders on the hat's parameter tab seem to have any effect.
Below a list of all the sliders that don't seem to do anything:
  • /data/shadownet3d/Witchykin Outfit/Witchykin Hat/Morphs/shadownet3d/Base/Adj Crown X.dsf
  • /data/shadownet3d/Witchykin Outfit/Witchykin Hat/Morphs/shadownet3d/Base/Adj Crown XZ.dsf
  • /data/shadownet3d/Witchykin Outfit/Witchykin Hat/Morphs/shadownet3d/Base/Adj Crown Z.dsf
  • /data/shadownet3d/Witchykin Outfit/Witchykin Hat/Morphs/shadownet3d/Base/Adj Fit X.dsf
  • /data/shadownet3d/Witchykin Outfit/Witchykin Hat/Morphs/shadownet3d/Base/Adj Fit XZ.dsf
  • /data/shadownet3d/Witchykin Outfit/Witchykin Hat/Morphs/shadownet3d/Base/Adj Fit Z.dsf
  • /data/shadownet3d/Witchykin Outfit/Witchykin Hat/Morphs/shadownet3d/Base/Brim Size.dsf
  • /data/shadownet3d/Witchykin Outfit/Witchykin Hat/Morphs/shadownet3d/Base/Hat Size.dsf
  • /data/shadownet3d/Witchykin Outfit/Witchykin Hat/Morphs/shadownet3d/Base/Loosen Band.dsf
Any help available?
  • Richard HaseltineRichard Haseltine Posts: 111,363
    Have you checked the log file after loading the hat into an empty scene to see if there are any errors at the end?
    Just did that and in the log it says (when loading only the hat):
    2019-07-03 20:25:07.855 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(4679): Could not find node parent.
    2019-07-03 20:25:07.896 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(1770): Failed to follow node.
    OK, that just means it can't fit to the base figure. Try it with a Genesis 8 Female in the scene, though I'd expect any issuse related to thsoe morphs to show on a stand-alone load.
  • felisfelis Posts: 6,502
    I just tried it on a G8F and can confirm that the morphs on the hat seems to have no effect.
    Please open a Technical Support ticket to report this as a possible bug.
  • s-m-c-10s-m-c-10 Posts: 5
    I'm having the same problem.
    I'm sure there will be a post here when it is fixed.
