Fluidos Plug In Not installing
Luv Lee
I noticed a while back that someone said they had an issue installing Fludios and used the DIM installer. I usually skip that because I haven't had the best of luck with it, but decided to do so in this case. Now, I am having install issues. Seems no matter how I install, either manually or via the DIM Installer, I can't find the Fluidos plug-in so I can input my serial number, or the presets won't load ... is this due to it being a new version of DAZ? IS there a work around?
Thanks for any help ya'll can give me.
A
Do you have DIM using a network drive to store the download cache? I ran into an issue with that and installers that have executable files in them.
Don't think so--but my hubby helped me customize my install set up so I can sync my render boxes... will check that out. Thanks for the head sup--could be a directory issue.
Hey, Alberto helped me figure out it was an issue in the DIM install directory -- I had not checked ON for Plugins. It' installed and ready to go :-)
