Anyone knows how this one works?
HeraHera Posts: 1,972
edited July 2019 in The Commons
Hello!
I found a product I've bought about a year ago, which I cannot figure out how to work. As I understand it's a second skin thing for V4, but it doesn't load when I'm clicking the icons in runtime/poses. Anyone knows what I'm doing wrong? And how it's supposed to work?
Post edited by Hera on
    Seems to be shaders, did you select both the figure and the surface when trying to apply?
  • Richard HaseltineRichard Haseltine Posts: 111,992
    Is this in Poser? I think it is reliant on the Poser shader tree despite the stuff about Connect.
  • JOdelJOdel Posts: 6,322
    That series of body jewels were built with Poser procedural shaders, so I don't think they work in Studio. I think they came over with the RDNA aquisition.
  • NorthOf45NorthOf45 Posts: 5,924
    Yeah, Poser shader tree, and Python scripts, too, so no go. You can make something useful if you set them up manually, and maybe use a Geoshell or a layered shader to arrange the different pieces. All the bitmaps are available (diffuse, bump, displacement, opacity, specularity) to drop into the empty channels. I tried a few and got good results, but , um-m, nothing appropriate for the forum...
    edited July 2019
    Okay, so if anyone is still interested (too bad they are no longer available here) I redid a few renders that should pass ToS.
    Two with V4 in 3DL,
    and two with G2F (V4 UV) in Iray
    800 x 800 - 548K
    800 x 800 - 604K
    800 x 800 - 582K
    800 x 800 - 604K
    Post edited by NorthOf45 on
