How to change perspective?
Leo ChenLeo Chen Posts: 697
At the default setting, it look like as using an wide angle lenes!
How to change it to another angle?
(ex. 28mm -> 50mm or 85mm)
  • JaderailJaderail Posts: 0
    You must be using a CAMERA then you select the Camera in the Scene Tab and Change the Camera settings in the Parameters Tab.
  • Leo ChenLeo Chen Posts: 697
    Appreciate,Jaderail.
    edited December 2013
    I just add camera and change angle but the rendered image has nothing changed.
    How come?
    1918 x 996 - 559K
    1918 x 1030 - 575K
    Post edited by Leo Chen on
    That is because you are using the Perspective View. Change to the Camera like this...
    313 x 234 - 13K
    O, thank you again.
  • macleanmaclean Posts: 2,438
    Have a look at my tutorial. It explains everything you want to know.
    http://digilander.libero.it/maclean/DStutorial.htm
    mac
  • Richard HaseltineRichard Haseltine Posts: 111,998
    If you are using DS 4.x the interface has changed slightly from mac's tutorial - the magnifying glass on which you right-click and drag for focal zoom is now in the strip of icons down the edge of the viewport.
    mac
    Thank you for sharing,maclean.
    Thank you,Richard Haseltine.
  • Miss BMiss B Posts: 3,071
    What I have always done with every version of DS I've used over the years, is to create a a camera with a general setup that I like as a starting point, and then save it as the new Startup Scene.
    Then I go to Edit > Preferences and click on the Startup Tab and for Default Scene, you browse to where you saved your StartUpScene file.
    Then click on the Scene Tab and for On "New", again browse to where you saved your StartupScene file.
    Lastly, click Accept, and you should be all set. :coolsmile:
    Easy way? Set Preferences to START with default Camera. Then you start with the Same default Camera every boot of DAZ Studio.
    417 x 583 - 42K
    Post edited by Jaderail on
    Thank you, Jaderail and Miss B.
