Possibel to remove smoothing modifier from parameters?
cosmo71cosmo71 Posts: 3,609
Hi, is it possible to remove the smoothing modifier from the figure paramters?
  • KatteyKattey Posts: 2,899
    Yes. With figure selected in Scene tab, go Edit (top menu) -> Figure -> Geometry -> Remove Smoothing Modifier
  • BejaymacBejaymac Posts: 2,002
    Kattey which version are you using, because there isn't a remove option there in the current general release, you need to use the options menu in the Scene tab to find it (it's under Edit).
    DS 4.6.1.33
    Top menu Edit -> Figure -> Geometry -> Remove Smoothing Modifier
    Alternatively, right click on Scene tab label, Geometry -> Remove Smoothing Modifier
    edited December 2013
    I didn't install CMS or DIMM either, so I'm a bit lost why you don't see it.
    My Edit (Scene) tab also looks different. What layout do you use?
    Post edited by Kattey on
    It's a custom layout that I've been using more or less since we got darkside, but it's originally based on the City Limits layout.
    Guess my User preferences in Appdata are long over due a clear out, as I don't think the differences are due to me deleting plugins I have no use for or that are crap.
  • cosmo71cosmo71 Posts: 3,609
    Bejaymac said:
    I'm using the same build, but as you can see from the attached pics I don't have the option to remove it under the main edit menu, wonder if it's because I don't use their spyware programs (CMS & DUMB).
    thank you :) all of you :)
    thank you all :)
    I don't know, maybe I've messed up. Just noticed it says 4.6.1.33 Public Beta but this can't be because I can't download any betas due to them being on DIMM only download and there wasn't any 4.6.1.33 betas (the beta before had a different number) if I recall correctly. I remember installing public release(s). And as ERC freeze works, it can't be older public release.
    There should be a utility script "Update and Merge Menus" to update your menus.
  • Richard HaseltineRichard Haseltine Posts: 111,306
    Note that it will remove default actions you have moved or duplicated to another menu, but not custom actions.
    NIT PICK WARNING: DIM = DAZ Install Manager DIMM = Dual In-line Memory Module
