Problems with using Gen 2 to create morphs.....
StippleStipple Posts: 0
Hi
I am trying to create some morphs via blender for Gen 2 figures. I have done this for V4 by exporting OBJ file - going into Blender, editing object then outputting it as another object - using morph loader pro and job done ! However with Gen 2 I can save the OBJ file, then even if I try and simply use that (i.e. just read it straight back in) with Morph loader pro then I get the message :
Loading morph V6HD...
Warning: Geometry did not match, failed to create morph.
At a bit of a loss on this one - any suggestions welcome.
Thanks in advance.
  • Richard HaseltineRichard Haseltine Posts: 111,598
    Make sure you set the resolution to Base, otherwise you will get the SubD mesh which won't work. Parameters pane>Mesh Resolution group.
    You need to export G2 at Base resolution in the Parameters pane.
  • StippleStipple Posts: 0
    Thanks for the answers --- this has solved it.
    cheers
