Daz Studio freezes when I run the software every time.
And I can see (no reply) after the Daz studio 4.11 Pro logo.
like this what I attatched.
Whay should I do to fix it?
Thank you.
1273 x 578 - 33K
  • here is my log.file
    WINDOWS 10 MACHINE WITH 48GB OF RAM AND AN Nvidia 2080ti graphics card
    and AMD 2990wx.
    Any help would be appreciated.
    txt
    txt
    log.txt
    47K
  • mwokeemwokee Posts: 1,275
    I had a similar problem. The video card was going bad.
  • davegvdavegv Posts: 166
     I don't know if this will help but the last line of your log is at the "open GL Shader"
    DAZ Studio needs OpenGL 1.3 or higher..... this can be found at NVidia's site you may need to upgrade the firmware/drivers
    Look about 2/3 through the log file, just above "Scene Cleared". The OpenGL is already at 4.6.0 and (down near the bottom) the NVidia driver version is 430.86 — both are well above minimum limits, so something else has to be the problem. Maybe the graphics card isn't securely seated in its slot?
  • Well, if you figure it out, please post.  Mine is freezing, too.  It's acting goofy.
  • Thank you guys, I will try it. And will post it, if I figure it out.
  • I received this message from help desk.
    and i perfectly works!!
    Hello,
    Please rename the plugins folder in the Daz Studio install directory (C:/Program Files/DAZ 3D/DAZStudio4) and launch Daz Studio. If it runs please let me know. You can rename the plugins folder back to the original name and then move "dzdynamics.dll" out of there and launch again.
