Light Set and HDRI dome SCENES!? Why? How to change them to ...
Anything else but a scene!  I do not work by starting with lights and domes, which is the only way I have found to keep the darn things from erasing my work .... they always say "want to save your work before...) Sorry, No. I refuse to do it that way. I loose all sense of creative flow. I need the domes and the light sets to load as a dome or a light, not a scene.
I realize many of you will think I am just being stubborn, but I really do loose my creative flow. I can't explain why; but I work from character to props to scenes to lights. Any other way just scrambles my brain I guess.
I must be missing something, because a lot of domes and light sets are sold this way, including those created by DAZ.
What do I need to do to get these items to work my way?
Thanks..
  • kenshaw011267kenshaw011267 Posts: 3,805
    Use merge rather than open?
  • thrain9thrain9 Posts: 108
    edited June 2019
    @kenshaw011267... Thanks for the reply.  that method does work for a few of the items, but not all.  No clue why that is the case.
    Also that method loads the entire light setup, and sometimes I want only one or two of the lights (yep I know I can load 'em, then delete or turn off the pieces I don't want, but some of them are not so "intuitive" as you might wish.  I've lost critical pieces of the light rig doing it that way.)
    Post edited by thrain9 on
  • Richard HaseltineRichard Haseltine Posts: 111,380
    If they are Iray you could save a Lights preset (for the actual lights) and a Render Settings preset (for teh dome) and apply both to your scene.
    edited June 2019
    Yes, Iray sets and domes.
    @Richard Haseltine... Thank you.  I will probably load up a "throw away character" after loading the light/dome scene to test out what is actually happening to my render, then make the presets.  ie. before I "go insane creatively" and try to make anything I actually want.  A fair amount of work.... but it would beat the frustration I feel now.
    for your information: It is crazy important for me to rapidly switch lighting and domes in and out of my viewports without disturbing anything else, I work fast and free, using sliders, quick clicks etc. the faster the better for me.  just the way I am wired, I guess.
