What is wrong with my shadow?
I'm trying to render with raytraced shadow,
I've attached two pictures, the first one with the raytrace shadow applied and shadow softness 22% and 0% shadow bias
and the other one is just a render without any shadows
if you look close enough in the first one you'll see shadow fuzziness, i want to know how to make a clean shadow
additional information, the light i used is distant light with nothing between the model and the light, the light intensity 100% and and DOF enabled on the camera the model is genesis female.
242 x 406 - 34K
217 x 372 - 23K
    What are your render settings? The softer the shadows, the more demanding they are of higher samples.
  • JaderailJaderail Posts: 0
    To my eyes I see Uber Enviro lighting. That needs the SAMPLES (Quality Settings) Raised to remove the fuzz.
  • SzarkSzark Posts: 10,634
    edited December 2013
    you set shadow softness to 22% and want crisper shadows, turn softness down then. :)
    Unless you mean the grain, then yes Render Settings is your key or what Jaderial said.
    Post edited by Szark on
  • edited December 1969
    Thanks a lot, right it was the shadow samples.
    I raised it from 16 to 32 and it worked great
    thanks again
