Can't install 8.5 from install manager - Install Failed
TurnerTurner Posts: 116
Just upgraded; it was recommended that I use the Install Manager, which I've tried, but continually get the "Install Failed!" message.
I'm on OSX 10.9.
Any help appreciated.
cheers
Andrew
  • TotteTotte Posts: 15,278
    Have you changed any default locations in DIM, and do you use the latest version of DIM (there were some Carrara related fixes in the latest release). I know DIM autoupdates but you can most likely make it not to.
    When installing Carrrara 8.5 , what directory does it try to install to, do you have anything in the DIM log that looks interesting?
    To show the log, click in the "Cog" and do Show Log...
  • TurnerTurner Posts: 116
    Hi Totte-
    thanks for your help.
    I have downloaded the newest version. (Didn't actually have one before)
    I haven't changed any default settings.
    However... I couldn't find the installer when I went to check the directories!
    So... reinstalled, working now :)
