Can this outfit/Geoshell be worn by any G8 Female, or only the character it comes with
CarlCGCarlCG Posts: 114
Is this outfit designed to only specifically fit the character, Syph bundled together with it in the package?
https://www.daz3d.com/syph-and-bodysuit-for-genesis-8-female
The product page doesn't list that it will fit any other G8 figures, so I'm wondering if it can only be used by this Syph characrer.
    I can't think of any reason why it would be locked to only the Syph character. In general, any Geoshell made for one character applied to a Genesis figure will also work with any other character on the same Genesis figure. In this case, any G8F character. Although it might not look as good, if the character is very different in shape (a lot bigger, smaller, fatter, skinnier, etc. or an alien critter) from Syph.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,749
    edited June 2019
    Well since it is shaped with morphs to look like an android I suspect you are initially stuck with that body shape but can probably add other morph dials
    it does at least say separate head and body morphs
    no doubt you could dial in smaller hips breasts bigger thighs etc though as you choose but that would be your base to start from
    someone with it needs to post as I looked at it a few times too
    edited June 2019
    I might be able to tell you later today because I just bought it in the sale, too cold to get out of bed and download at 4:30am in Adelaide at the moment maybe in 6 hours time!
    sale will still be on hopefully
  • CarlCGCarlCG Posts: 114
    Thanks for the responses @SpottedKitty and @Wendy_Carrara.
    I appreciate that, and I'm glad someone who owns it might be able to let me know how it works out. I was just wondering because the Syph character looks almost child-sized, so I'm wondering if even morphing from her as a base might still be limited to a very small figure.
    I think I got my answer, I went ahead and bought the item too...it seems to load just fine as a wearable on my G8F figure without any additional morphs. I haven't fully rendered but just going by what I see in the Iray viewport it looks ok.
