GOZ open new DS
Hi Folks,
I can send my work to ZBrush without any problem, but when I use Goz, it opens a new DS... I remove goz, the set up again a few times then it works but this happens often and makes me crazy... Do you know any permanent solution mates? Thank you.
DS 4.10.0.123 Pro Edition (Win64)
DS4_GoZ_1.7.0.123_Win64
  • Richard HaseltineRichard Haseltine Posts: 111,363
    Sometimes resetting the DS path in the ZBrush preferecnes will help with this.
  • marth_emarth_e Posts: 191
    It happened to me too and the only thing I've found that fixes it is to make a copy of your C:\Program Files\DAZ 3D\DAZStudio4\DAZStudio.exe and rename it as DAZ.exe, for example. Now you execute the new exe file.
    That sounds risky, and should not be needed.
    But it works... While reinstalling and updating the paths won't.
    I've never had to do more than update paths, and what happens if it then fails after the renaming? Or if you update DS? It sounds like some underlying issue is being stepped over rather than resolved.
