"GYN-01 for Genesis 8 Female" problem using it on figures
chromchrom Posts: 261
I tried using [GYN-01 for Genesis 8 Female] it on another figures. But seems not to work like in product photos.
My results are only something like bodypainting with weak depths (e.g. ribs) also at 100% morph.
Any suggestions?
  • Richard HaseltineRichard Haseltine Posts: 109,214
    It sounds as if you are not applying the HD morphs, or lack the SubD levels to show them properly. Are you rendering in Iray? By the read me ( http://docs.daz3d.com/doku.php/public/read_me/index/61581/start ) theer appear to be options to load with and without the moprhs - make sure you are using the right one (I suspect this may be a product that's easier to use from the Content Library pane under Daz Studio Formats, so that you can see the folders indicating the flow)
  • fastbike1fastbike1 Posts: 4,081
    I've seen Gallery images with this outfit, so it definitely works.
  • chromchrom Posts: 261
    I used iray and tried all loadings also only seperated armor but from smart content > explore product.
    Regarding gallery:
    I searched for "Gyn". The most pics are from the producer itself. I found only two others:
    https://www.daz3d.com/gallery/images/815516/
    orignal figure - seems not be applied on another figure
    https://www.daz3d.com/gallery/#images/810456/
    bots on the sides looks like body painting.
    front figure has depth but don't know if original or perhaps head changes to original
  • nemesis10nemesis10 Posts: 3,893
    Regarding gallery:
    Two part question: when you load the morphs on G8F, in the Parameter settings>What's being used, do yoy see the morphs, and what is the subd level you are using?
    thank you. subd is the solution :)
    (and a little bit rescaling)
    I am wondering about that a product needs manual adjustments for its usual/mentioned use and that thea are not described.
    Is this normal or/and when should I be aware of manual subd, ... changes (figures itself, morphs, ...)?
