Ultrascatter fails on 4.11?
I upgraded to 4.11 a few days ago and now when I run Ultrascatter, it doesn't seem to work. I get a node that says there is an Ultrascatter object on the target object, but there are no actual instances. It still works on 4.10, but 4.11 shows no instances, rendered or not. I don't have Ultrascatter Pro, just the original version. Do I need to upgrade to get it to work on 4.11?
Thanks in advance for any ideas.
  • LeanaLeana Posts: 13,501
    You say it still works in 4.10, so my guess is you installed the beta version of 4.11.
    Did you have a previous beta installed or is it the first time you installed one? If it's the first time then the plugin may be installed only in 4.10, not in the beta, in which case you'd need to reinstall it.
  • lulamfadalulamfada Posts: 77
    Thanks for responding! I don't have the beta version, but I hadn't tried a reinstall. That seems to have worked--though DIM refused to see the files, so I had to do a manual install. Weird.
