Hiding Walls For IRAY Render >>RESOLVED
I know that when rendering a scene in IRAY that if you remove a wall so that the bouncing lights have a way to get out speeds up the render, but will just hiding the wall do the same thing?
Post edited by cheznous2029_28ab1adedc on
  • chris-2599934chris-2599934 Posts: 1,957
    Yeah, it shouid do.
    @cheznous2029_28ab1adedc
    You can also limit the maximum number of bounces. The default is infinite, but changing max path length (Render Settings>Editor>Optimization>Max Path Length) to a value between 7 and 10 will help speed rendres without compromising quality.
    Thanks for this suggestion, now all my scenes have at least one wall hidden or a door open and I set Optimization-Max Path Lengh to 7, which seems to work fine for me.
