To hide some parts of Josie under clothe
ArokariaArokaria Posts: 15
edited December 1969 in Poser Discussion
Hello !
I am using Josie in Poser Pro 2014. When I try to use clothes, I should like to hide leg, for example under pants to avoid to see flesh through the fabric. But, unfortunately, the visible option doesn't work in properties tab ( of left thigh of Josie, for example ). This option works very well for the pants, which is useless. I have same problem with V6.
Somebody could help me ?
Thanks
  • Richard HaseltineRichard Haseltine Posts: 111,388
    Theer should be a dial for subdivision level on the body part - turn that to -1 and you should be able to hide the part.
  • KeryaKerya Posts: 10,943
    Stupid question, but I have to ask:
    Did you
    Script menu / DSON Support / Transfer Active Morphs
  • ArokariaArokaria Posts: 15
    Thanks for the answers
    I Set subdivision off and it solves my problem.
    And what is the meaning of Transfer active morphe ? I will try to find documentation about this.
    Regards
    Transfer Active morphs projects the morphs that are currently non-zero (and set to auto-follow) into the clothing, creating a morph in the clothing. It works better for some morphs than others, as with any automatic transfer, but it is better than no morphs.
    Thank you every Richard and Kerya for the answers
